After 6 years the inevitable has happened.
Hastily set up sleep site in a bothy and i managed to sleep on a staple embedded in the paint :/ it was obvious in the daylight,
Woke up on a flat neoair after a good nights sleep.
Ive found the hole – its in the bottom – its a pin prick as you would expect.
The base is polyester – so ive been advised not to use a puncture repair kit – vulcanising rubber is not what i need apparently.
I have a stormsure repair kit – looking through that im wondering if i can get away with just using the glue – even if it is on the outside of something under tension – which is similar to a tent where even stormsure suggest not using theri glue.
Ive been reading other pages that say a drop of superglue on the hole should seal it.
The hole is in one of the valleys of the ridges on the bottom so getting a good seal with a patch is going to be hard
