Best all round if you just got a sparky to do it for you, as mentioned above some form of Part P certification will be required for the work, SWA cable is not a “must” there are other options also you might need to look at some sort of ingress protection for the lights and accessories etc. There are also other factors to consider such as how far the out building is away from your house and what type of earthing arrangements you have, this will have an influence on what type of earthing system employed at the out building i.e. you shouldn’t export a PME (TN-CS) system outside of the house.
