I have flouro lights under my kitchen wall cabinets that are hard wired direct to a light switch, presumably on the lighting circuit.
I want to change them to LED strips, and the ones I want come supplied with a plug. I’m planning on cutting the plug out and connecting them to the existing wiring, but am worried that by doing that I’ll be losing the fuse that would otherwise be in the plug.
So, question is, is there anything wrong with doing that, and should I put an FCU in between the switch and the lights, with the fuse from the plug in it?
Cheers.
