I've got a Bosch/Hotpoint hybrid as well and it has a similar problem.
There are 3 things that can stop water coming in. One is a blocked water softener, which is fatal. One is the inlet valve cut-off and the other is water in the sump, where there is a flood detector cut-off.
If the machine makes the same rumble whrever you turn the progress knob to (and the powder flap doesn't release as you turn it) then it's a full sump.
Solution – undo the inlet pipe and turn the unit on its side (or upside down). If you get a lot of water coming out onto the floor its the sump. Run the machine without the pipe connected for a minute or so (which will reset the cut-off if that's the problem.
It should be fine then.
I'm not a repair man, but I've been having a problem with ours and our local mender has helped me out on this.
Ours has a small leak, which fills the sump and means I have to tip mine on its front every 5 days to keep it going.
