I have fiat ducato 2005, 2.3jtd van (an iveco engine) and the turbo basically doesnt spool until about 2200rpm, previously it was about 1300rpm. This means that when loaded the van has very little power unless im driving allthe time in a low gear and ghe turbo is spinning.
Diagnostics show everything ok, the air mass sensor, all filters, oil has been changed. All pipes and connections checked and the egr, actuator gates etc cleaned.
Still the same problem, before The turbo is removed anyone here have an idea what the problem may be?
The problem seems to gave started when i got the clutch replaced, is there anything that could have been damaged when the gearbox was dropped?
Ta
