I have just put a couple of layers of UD carbon fibre onto the top tube of my bust MTB frame. I wetted out the 2 layers then applied a release fabric and then a breather layer and then vac bagged (25 MG). The breather fabric was also wetted right out.
I have just unbagged and removed the breather fabric, but the UD looks dry and I wasn’t able to sand it smooth. When I sanded, I could see small strings of carbon fibre. In the end I ended up sanding it all off with 80 grit back down to the underlying 12k weave.
Is UD difficult to work with as I was hoping I would be able to sand it like I can the 12K stuff so I could get a top class finish.
It had been vac bagged for 24 hours.
