well that was an experience! pleased i had my workmate with me who knows his way round cars 😀
did as you suggested ^^^, air filter out, gave it a bit more grunt, and hey presto, out came the airbox. lovely. ah yes, thatll be the reverse switch there right in that difficult-to-get-to place. bit of a faff to get to, also a faff to pull the plug off the end, but eventually got the switch out.
new switch, oh this ones got a washer on it, did the old one? no. oh well, it came with a washer we’ll fit it with a washer.
all back together again, airbox back on, drive forwards, drive backwards, er…… no reverse light at all now. radio still showing too, so it doesnt even think its in reverse, its worse than before!
right, whys this? bit of a chitchat, maybe its that washer, it may have altered the total length, so the plunger isnt in the same position and isnt being activated. ok, well take the washer off. more faff trying to get the plug off, got it out, took the washer off, put it back together again but this time left the airbox off so we could experiment.
forwards, reverse, nothing again. grrrrr……
then i noticed it. a broken wire, exactly the same as the pic above! pah. ok, we’ll strip both ends, join em, wrap em in tape, job done. fragile skinny little cable, it was like keyhole surgery stripping the ends, wrapped em together, job done. plug in and er…… oh, its split again. the joined lead now wasnt long enough to reach the switch, so pulled apart.
right, had enough now, its going to the garage! mate talked me into giving it one more go with a separate bit of wire joined between the two ends. pulled one off one of the scrap cars available to us, made 2 joins, covered them in tape, plugged back in, tried it before fixing everything back, it worked!
airbox back on, everything screwed back, i now have a working reverse sensor 🙂
thanks for your advice, and well done if you read that through to the end 😀
cheers
