I have borrowed one for a few weeks so unbiased view. It climbs very well and is light tackles very steep v tech well with shock open as it keeps loads of grip.
Great downhill, corners very well, but took some messing to get correct set up, can feel a bit low through really rocky stuff so you have to time the pedals to avoid strikes but I think that’s why it decends and corners so well.
Components are all a nice choices, wheels and tyres are great but need swapping to tubeless.
If you are between sizes I would go for the larger (longer) one but check the drooper height as the seat tube is quite long, also the front end is a touch high but flipping the stem and removing spacer sorted that you could also fit a flat bar.
Honestly i would get one with a PIKE fork, and that is from die hard fox fan, my new bike will have a PIKE.
