Viewing 16 posts - 1 through 16 (of 16 total)
  • Any body swapped coils in a Sektor DPC?
  • BFITH
    As above.. looking to swap out the stock springs that came on my Sektor RL DPC 2012…I’m bottoming out on the slightest drop off…not surprisingly as I’m a hefty 110kg!
    So, which spring would be best for my weight and how easy are they to replace?
    Ta
    BFITH
    Anybody?
    LoCo
    X Firm would be the correct rate for you, we may have one inn stock depending on travel if not we’ll be able to get hold of one 😀
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    robfury
    I weigh 110kg and got sektor s dpc from loco. Xfirm was great for me
    franciscobegbie
    I got an X Firm from bikediscount.de (sorry LoCo!)
    Was the only place that had them in stock at the time.
    Dead easy job. Took 10 minutes to do.
    cbmotorsport
    I was in exactly the same position. I have a set of Sektor DPC’s 120-150 2012.
    I was also finding the spring to soft (I’m about 88kg), and had a couple of over the bar moments as the suspension was prone to bottoming out on steep stuff and tucking the front under.
    I looked everywhere for a blue (firm) spring, and was told that nobody had them, and unlikely to get any more, so I had a fairly useless pair of forks. I ended up buying a set of 2013 Revs from Merlin to replace them, the air spring allowing me to sort the fork for my weight.
    I’ve still got the forks and will use them on another bike if I ever get hold of a blue spring.
    Sorry to ramble on, I guess that you should be looking at a black (x-firm) spring. TF Tuned or Loco would be a starrting point.
    They’re asey to fit, lots of online guides.
    Good luck.
    cbmotorsport
    Loco – no blue springs in by chance?
    LoCo
    Got a 150mm fixed blue in stock, just restarting router and computer as broadband playing up, will check dp ones in a mo 😀
    cbmotorsport
    crossing fingers, not holding out much hope….
    LoCo
    150 Xfirms available, Firms out of stock but should be available soon ish
    cbmotorsport
    Shall I’ll drop you a line in a few weeks. I definitely want one, happy to pay up front now if required mate?
    BFITH
    Thanks for the replies guys. How much for an xfirm 150 dpc loco?
    LoCo
    Drop us a mail
    BFITH
    Ok will do…..
    BFITH
    They’re easy to fit, lots of online guides.
    Any body point me in the direction of a guide?
    svalgis
    http://www.tftunedshox.com/info/rockshox_spring_fitting.aspx
    It’s the same procedure for DPC and fixed length springs.
The topic ‘Any body swapped coils in a Sektor DPC?’ is closed to new replies.
