I’ve just reroofed a big barn that was covered with that after it was damaged in a storm. My insurance co had it tested and it came back as being low risk (not saying yours is also but the chances are high).
When it was removed the builder I used (not a specialist asbestos co) simply wore disposable coveralls, gloves and a face mask. The roofing was wrapped, put into lockable ‘asbestos skips’ and removed.
Our type is pretty safe unless you smash it up, grind it into a powder and snort it.
If you want to remove it yourself:
1) follow the above safety clothing guidelines
2) don’t smash it up
3) Wrap it with two layers of visqeen and tape it
4) book it in with your local authority recycling centre – there will be one nearby’ish
5) watch out, it’s pretty heavy.
