Right, although I have decided not to buy new a Stans Olympic wheelset until later this year, I have decided to go tubless on my current rear (and possible front) wheel after two punctures at the weekend.
Might just pop up to my lbs to get it done (probably use thebikechain for this one), but what are thoughts on the following:
I have a DT Swiss 4.2D rim on the front and a DT Swiss 420SL on the rear (which I believe is basically a 4.2D). Is it a case of ripping off the yellow rim strip, sticking down some new fangled tubeless rim strip, sticking in a tubeless valve (glue or sealant to stick it in?), forcing on a UST tyre (I'm thinking some Nobby Nic or Racing Ralph USTs in 2.1" for racing), pumping really hard with a track pump until it pops on neatly, then letting some air out, injecting some sealant through the valve and going for a spin?
Does this sound like a sensible and reliable way to go?
Incidentally, since I don't want to change tyres all the time if they are tubeless (and won't get spare wheels until much later this year), Racing Ralph or Nobby Nic for a "one tyre does all" XC racing setup?
