Don’t take this as gospel as I have only done a single strip down on a reverb, but from what I understand about the method of activation of the reverb and the condition of the post I refurbished I would say if you’re confident that the lever bleed is good, then the secondary hydraulic system requires rebuild.
WARNING: the secondary hydraulic system with its IFP is more technical than just the air seal and bush strip down and features four 10 minute videos from SRAM and also requires ‘special tools’…
I only found this out because I didn’t watch the video first and found myself having stripped too far before realising!
What you will need is a length of 20mm plastic conduit with 125mm marked off from one end – unless your poppet valve requires attention, I was successful in rebleeding the hydraulics without removing the poppet valve by leaving the central tube slightly proud of its location and allowing fluid to travel back up the centre tube (if you watch the four part video this description will make more sense!)
I believe the ‘suspension seatpost’ effect is due to air in the IFP assembly via leakage from the top of the air spring. It was quite shocking how much dirt had found its way so far into the innards of the post!
