We had a kitchen fitted last year and at the time we asked the sparky to add in some extra lighting circuits (forward planning as we weren’t ready to actually use the new circuits yet).
Anyway, he added a double switch to operate an outside light and low level lighting for a decked area. He installed it and connected up all the live side & earth, leaving the neutral terminated (three wires).
At the same time he also installed all the other lighting in the kitchen, including a two-way switched circuit for all the three banks of lighting in the kitchen/dining area (ie, kitchen lighting, pendant light over table and hanging lights over a bar seating area).
On Saturday I finally got around to fitting an outside light so connected it up outside then wondered where on earth to put the three blue wires in the double switch (as it only has two L2s).
I first tried putting in Blue 1 & 2 in L2 (left) and 3 in L2 (right). I switched on the power and all seemed to be working until I tried the switch and it blew the circuit (tripped the RCD). I then spent half an hour trying different combinations and came to the conclusion that Blue 1 was connected to the pendant light circuit over the table so I terminated that one and tried variations of Blue 1 & 2 in both L2s but then I couldn’t get the outside light to come on at all.
So – Blue 1 is clearly needed to make a circuit but it seems to be tripping it when I use it.
I hope this ramble makes sense – I will be getting my normal electrician in (the kitchen fitters subbed their own sparky when the work was done last year) to check it properly (I did actually have him come in and check all the new work and certify it after it was done and he didn’t find any issues with any circuits then.
But in the meantime I would appreciate any thoughts/ideas that I could try before having him come in.
