Hi all
Sorry about another thread about going 1x!
Just ordered myself a new 29er which I intend running 1×10. I have a couple of questions however about the conversion.
My current xc bike has a triple but I never require the granny ring – ie i can get away with a 32-36 for 99% of my riding. How would this translate to big wheels? Would a 30/36 be similar?
If so will a 30 tooth fit on a sram x9 crank, or failing that an SLX crank. And if so can you recommend a cheap NW one?
If I end up deciding I need a bale out gear i’m assuming id need to replace the sram cassette with an xt version and a one up/hope extender. Will a sram x9 type 2 rear mech work with that set up?
Assume I can’t utilise a rad cage if I wanted to run this set up. How important is it to have this, or will the bike run ok with a standard x9 setup and 42 tooth cog.
Just trying to work out whethr its worth swappping the Sram stuff for XT before it gets used to give me more options in the future
thanks
