Any ideas, ive got a ticking sound that occurs once every revolution of the crank, only seems to be under load as I can’t replicate it with the bike stationary, im guessing it must be a pedal bearing or bb or crank bolt, aside from checking everythings tight, is it sensible to replace the bb, it’s a sealed square taper type, or do a pedal service first,or maybe just remove peldals, cranks and bb, regrease and reassemble? I guess a regrease would be logical but if I remove it all and reassemble and the problems still there, ill be none the wiser.
Thoughts? Cheers.
