Has anyone come across this sort of issue with their ‘smartphones’ before?
I have an HTC Desire HD. Just moved into a new house and the Netgear router there, although it has an excellent signal to my phone will not seem to allow me to connect to certain sites sometimes, most notably Hotmail and Facebook. Other sites load quickly and normally(although admittedly, some pause 3/4 of the way through and struggle with the last bit going by the green loading bar at the top)
Sometimes it does work, usually when I have looked at several other pages from other sites first and then come back to Hotmail etc, but only sometimes. STW seems to work fine by the way.
Other times it simply will not load the page at all and comes up with the usual error message ‘webpage not available’, as if not connected, but then will instantly work on pretty much any other site.
I’ve tried deleting all data, cache and all that stuff and once or twice that seems to have worked but then next time I want to access its back to the same problems.
I’ve power-cycled the router etc(turned it off and on again 🙂 ), re-started the phone several times, tried the stock browser aswell as Dolphin, nothing….
3g works spot on, wifi at work, works fine.
Any ideas?
Thanks.
