Viewing 21 posts - 1 through 21 (of 21 total)
  • and tomorrow this arrives so i will be fettling
  • WorldClassAccident
    Black, Pair – Bar Mount Shimano XT M780 10 Speed Trigger Shifter
    Silver, 11-34t, Shimano XT M771 10 Speed MTB Cassette
    Black, Medium Cage Shimano XT M786 Shadow+ 10 Speed Rear Mech
    Black, 104mm, 42.32.24t, 175mm, No BB Shimano XT M780 10 Speed Triple Chainset
    Black, 31.8mm/34.9mm, Conventional, Dual Pull Shimano XT M781 Conventional 3×10 Front Mech
    Black, 300/600mm Outer Shimano XTR Gear Cable Set PTFE Coated
    Silver, 116 Links Shimano XT HG95 SIL-TEC 10 Speed Chain
    Any idea how to remove the drive side BB so I can get rid of the old e-mount chain guide that has welded itself to the frame?
    It is currently soaking up the oil and penetrating fluid hoping it will move in the morning
    alandavidpetrie79
    Thanks for telling us the colour of the bits & bobs…..
    JoeG
    Which way are you turning it to loosen?
    honourablegeorge
    You’re turning it clockwise, right?
    WorldClassAccident
    I tried both ways 🙁
    Any advice?
    cchris2lou
    proper tool and a long pole .
    WorldClassAccident
    I have the proper tool.
    On the drive side, it is the normal thread pattern right? Lefty loosey, Righty Tightey?
    Please confirm because tomorrow I will move on from muscle power to a 4lb lump hammer.
    Thanks
    WorldClassAccident
    Just read the link – Is it a reverse thread?
    Please let me know for certain
    Saccades
    jivehoneyjive
    Is it a steel frame?
    If so, soak in coca cola (or pepsi)
    The phosphoric acid should help free it up
    Graham_Clark
    Drive side – Left hand thread, so lefty tighty, righty loosy
    orangeboy
    Bolt bb tool into cup with crank bolt , large bar with socket and apply steady pressure
    Oh and English shell will unscrew clock wise
    WorldClassAccident
    A night soaked in oil and a slight tap with the persuading hammer and it releases smoothly
    Thanks
    toppers3933
    Also helped enormously by turning it the correct way too. 😆 🙄
    MTB-Rob
    For “Normal” BB to undo, turn towards the front of the bike.
    A tip passed to me many many years ago.
    WorldClassAccident
    Smooth shifting and silent loveliness
    I had forgotten how nice new transmission shifts are and Shimano is so easy to install and set up
    Marko
    It’s always DRIVEL:
    DRIVE (side) = (equals) LEFT (hand thread) 8)
    Hth – in the future
    Marko
    paul4stones
    Except for pedals 😉
    andyl
    but what if you put the spanner so the handle is down at the bottom?
    the way I remember it is by remembering that if a BB jams it will undo from the frame under normal pedalling and push out onto the crank arms instead of tightening and jamming into the frame.
    WorldClassAccident
    Once I had removed the BB I saw some little writing saying TIGHTEN with arrows pointing the right direction to tighten the BB. If only they had ones saying loosen I would have been alright!
The topic ‘and tomorrow this arrives so i will be fettling’ is closed to new replies.
