Hard water area here. We have a water softener for the main house supply, and a reverse osmosis filter system for drinking water taken off before the water softener. Much better than the Brita filter jug we used at our old house.
As a bonus to tasting better we haven’t had to de-scale the kettle once since moving to this house with the RO system fitted.
it won’t be a RO system, that would be dangerous as the water would strip minerals from the body.
Biggest con since food supplements. A filter doesn’t remove dissolved molecules like chlorine and calcium, which is why the kettle still scales up.
chlorine doesn’t cause scaling
Generally hard water tastes better than soft;
no, it’s the other way around. Ask anyone who lives in Oswestry
it’s probably the chlorine you’re tasting because your water is coming out of a borehole or a river and is needing to be treated heavily
boreholes in a “good” catchment need little treatment and often were only dosed with chlorine. Crypto risk has meant that now the treatment is beefed up
river water always has needed high levels of treatment due to the variability of the water quality etc (high rainfall events), in addition river water is “softer” than borehole
taste issues are complex but generally there are less complaints in “soft” water area’s, hard water is arguably bteer for you as less dodgy minerals (lead) are absorbed in distribution to the tap
