Courtesy of Google Translate:
“The Schwalbe and Syntace known firms are combining their expertise and resources to develop a new idea that promises to revolutionize the world of indoor cycling : a new wheel-tire system with dual camera for the latter . The benefits of this system: ability to shoot low ( very low ) pressures on deck, more grip on all types of terrain, substantial improvement in the control of the bicycle and also greater protection against shocks and tires / undercuts or cover unexpected .
As you probably know , the performance of a mountain covered improves significantly when shooting at low pressures , offering more grip and control in all types of land (mostly abrupt ) . The problem of shooting with low air pressure on the decks is none other than the increased risk of suffering a puncture , pinching and / or beating on the bike tires , all ingeniously solved by the new (and very next ) wheel-tire system developed by Schwalbe and Syntace signatures.
The concept of this new system is very simple and ingenious , similar to that developed by Nuetech system. Basically, it tries to place two air chambers inside the cover. In the innermost part (near the rim ) , a chamber of high pressure air is charged with protecting the rim and tire to avoid undercut , plus tweaks , twists and all the air leaks on the edge of the rim. On the outside ( near the tread ), another tube handles provide maximum grip and control over the wheels , allowing carry very small air pressure without any associated risk.
Thanks to this new dual camera , Schwalbe and Syntace will offer us the ability to roll with a minimum air pressure of 12psi (less than 1 BAR ) in the outer chamber of our decks while the other air chamber (up to 60PSI ) will be responsible for maintaining our well protected from obstacles wheels. According to both companies, all runners who have tried this new solution is really good :
” The grip of the tires to 14 PSI is amazing. The contact area is very large and tires rarely , if ever , slip on loose soil . Even in the most difficult terrain tires stick to the ground .. . literally. “
This dual camera system is being designed to run on all types of roofs and wheels, tires assuming that include a second port for extra valve. With weighing nearly 200 grams of weight dual camera, Awaiting more details about this new system developed by Schwalbe and Syntace . Probably will be presented during the next edition of Eurobike 2014 with more precise information about its design, prices and patents pending. Coming soon , more details.”
