New shorter stem – something like a 50mm thomson x4
new seatpost in BLACK (thomson layback would be spot on)
the grey lizard skins peaty grips (red bits would match the seatpost collar)
Lose the red headset and chainstay protectors or get some in black
NEW DECALS
SLX crank
EDIT: – and the spring would look better in bare metal finish
“New shorter stem – something like a 50mm thomson x4”
Why?
It has a 130mm fork, with roughly a 90-100m stem. Its not not ridiculously long, but long enough that the bike ought to be able to climb quite well
Presumably the rider is quite tall so cramping the cockpit will make it pretty poor to ride?
From a design point of view, i’d loose the all the red bits! The headset and chainstay protectors make it look untidy too. When money comes available swap these bits, but fit a black adhesive chainstay protector and also an airshock to get the weight down. Some nice components on there and the yellow is a big improvement over the pink!
If you like your ride, why buy a new bike? It’s the beginning of a new era of “mend and make do” and what you have done is really cool. We have been throwing good stuff away due to a crazy over consumption habit we have formed over the past couple of decades. The problem is one of compatibility – manufacturers have a hait of making it quite difficult to switch bits around.
I’m about to start my 3rd rebuild. It’s great fun searching out bits and getting a bike together. The worst job is stripping a frame ready for refinishing, but for me, the day I wheel the finished article out is more satisfying than when I got a new bike.
Eddy that is pure class. ignore them. Of course, I compare everything to Gary’s famous Christmas Tree K2 Razorback so my eyes may be permanently damaged.
I could just turn the skins inside out to make them black but then I’d be conforming to the masses. Can’t believe I didn’t think to get the spring done at the same time, DOH!
it looked better before. and i’m saying that from a position of seeing it before it went off to be painted and assuming the “after” shot would be an improvement.
still, what’s done is done. now i would say make the best of it by at least removing everything red and silver from it in favour of black and getting some big black decals for it as well so at least there’s some sort of theme.
I like this. It looks (and this is intended as a compliment) oddly similar to the Heckler that John Powell (?), the president of Bristol Uni cycling club, had when I first joined it in 1997. I was hugely impressed with that bike and it had a profound effect on my bike aesthetic sense, which was pretty fixed by the end of the 1990s. A a lot of what has happened since in style terms has not really pushed my buttons. But this looks delightfully retro.
I suspect I would like it even more if the swingarm was mid blue mind… 🙂
