+1 for excellent service and good products.
Got some very old XC and Bulb hubs, friends still runs the even older splined/5bolt ones!
Pro2’s ahve been great, original rear split and was replaced and the wheel rebuilt in a week! New ‘evo’ has been faultless through the winter on the SS (so possibly the worst place for a hub, mud, high torque, hardtail, and I’m not the lightest!).
Brakes, I’ve had a few problems, old C2’s sprung a leak, they were 2nd hand and about 8 years old, hope charged me £20 to rebuild them!
lost the pad retaining pin out of some mono mini’s, hope sent a jiffy bag of them out FOC.
Just rebuilt my well used mini-X2, good as new again. And it only took a few minutes to bleed (admittedly I’ve got a vacuum bleeder which makes life so much simpler), no propitiatory threaded nozzles, no funneled fittings to lose, no need for 3 arms and lightning reactions to get plugs back in before the fluid pisses out, no need for instructions, they just bleed like normal hydraulic brakes. Why do other manufacturers insist on re-inventing the wheel?
Compare that with Shimano, “i’m sory your brakes leak, but the only way to fix them is to bin them and buy these new ones”.
If I could justify the cost I’d get everything from Hope!
