- This topic has 67 replies, 36 voices, and was last updated 10 years ago by bigmountainscotland.
Amazing Alfine? Or not?
bobloFree Member
It’s not ancillaries like the nut/cable that are a concern, it’s the magic inside. If the spell wears off, how would you fix it when out and about?
I did a 50 on mine yesterday, all bridleway/offroad (though in the Fens so a bit tame). The shifting is very good but you need to be positive with the changes and back off a little to avoid expensive noises.
There is a slight risk with Versa levers in that the cable adjuster is a bit free to move and can/does if you catch it when moving around on the bars. I’ve put a drop of threadlock on mine and added a telltale so I can see at a glance where the adjustment is.
The only real downside for me is the weight and the ride feeling a bit dead compared to other bikes I have. Still fancy a Rohloff if anyone is moving one on?
hjghg5Free MemberI’ve done just over 1200 miles on my alfine 11 and no major issues. Getting the knack of the gear changing took a while but I seem to be there now, and I’m getting used to the weight. It’s not on a particularly light bike to start with so by and large I’ll just be pootling on it anyway. For fast road rides I’ll use a standard road bike, but the pompetamine with alfine is great for rides with a mix of road/cycle path/track.
No leaking issues here even after I serviced it myself (I was a bit worried I wouldn’t get the seal right).
I’ve recently been touring on it. I was a bit wary about using panniers and adding even more weight to the back, but it was fine – except trying to get it through gates…
ndthorntonFree Memberand the ability to fakie without the chain derailling
what is a fakie – sounds impressive on a bike if its anything like the snowboarding equivalent!
+1 for more gearbox development – the hope of this is the only reason I havent converted to hub gear. put me down as an early adopter for gear boxes though. It should work great for 160mm Enduro bikes – Putting the weight in the middle of the bike – reduce the unspring + rotational mass of a hub gear. And it should be possible to run with no chain tensioning too if the suspension is designed correctly.
andylFree Member11 speed at the cranks, double or triple hub gear on the back.
Plenty of range, better weight distribution.
nickcFull MemberI’d like a 3/4 speed wide range hub as well.
Tried a Rolhoff, never tried an Alfine, things that put me off in no particular order ; weight, price, noise, serviceability, crap shifter. I guess I could used to the weight, price of the thing was unbelievable, I think I worked out that I could get ten years of normal gears before I’d break even. Rolhoff want it back to do a service, that’s sending a hefty bit of kit back to Germany….and no trigger shifter and a really shit quality twist grip thing that was an embarrassment given how much the thing cost.
I can see the appeal if you’re a frequent destroyer of normal gears. In 15 years + I’ve never smashed a mech or been unable to set up gears so they work properly and noiselessly. For me it’s solving a problem I don’t have.
ir_banditoFree Membera really shit quality twist grip thing
I thought mine was, until I replaced the cables. Bingo, super-smooth and easy now 🙂
Jagwire brake-outers (with lining), and standrad gear inners FTW. I’m just looking into using some V-Brake noodles to tidy up cable bends into the shifter and click-box.
thepodgeFree MemberI can’t see a 3 speed hub being much lighter than an 8 or 11
gofasterstripesFree MemberThe Grip Shift on a Rohloff is a bit industrial, but it’s made from Aluminum, Nylon and Steel with a thick bonded Rubber grip and so-far has proved in my case extremely hard wearing [4 years, maybe 50% worn]
According to my copy of the Bodyspace textbook [Ergonomics and such], three sided grips provides more purchase than round ones, and the diameter is 38mm which should provide approx 70% of peak torque about the axis of rotation [Max @ approx 70mm which is a bit big for a bike gripshifter].
While it is rather heavy and rough looking I find it delivers a nice mixture of fast block shifts with the thumb and finger grip and single fingertip and thumb shifts when cruising.
Lastly, having just serviced mine, I can say that a smear of teflon-grease on the mated surfaces and new inners and outers really makes a difference. I use a tiny wipe of Lumpys Crack Wax on the gear inners too, and then thread them into spiral-wound lined brake outer.
gofasterstripesFree MemberOn the Alfine, I am using the Nexus 8-speed gripshift, as I understand the trigger shifter is limited to single shifts.
avdave2Full MemberMy Rohloff shifter is still running the original cables after 7 years with no adjustments required. It is a bit basic but I can live with that for something so easy to live with.
bigmountainscotlandFree Memberwhat is a fakie – sounds impressive on a bike if its anything like the snowboarding equivalent!
A fakie is rolling backwards, still trying to work out if the one at 2:05 in this vid is real:
[video]http://vimeo.com/31659543[/video]
KZP894Free MemberI have an Alfine 8 which has run flawlessly for a few years. It’s simplicity makes it fun to ride and I have it on a 29er which I commute to work on etc. On longer rides I feel there is mechanical loss but this is probably just my fitness. Changing tube when you get a flat is a bit of a faff.
The 3 speed would be interesting but it would need to be a wide ratio 3 speed as the current offerings appear to be approx. 185% range (see http://www.hubgear.net/table.html). I ran a ‘singlespeed’ with a triple on the front for a while which worked quite well, just gives 3 very widely spaced gears.
epicycloFull Memberboblo – Member
It’s not ancillaries like the nut/cable that are a concern, it’s the magic inside. If the spell wears off, how would you fix it when out and about?…Most hub gears are stone axe reliable. Problems are usually down to cable maladjustment. The Alfine 11 has been the exception and is seen as fragile. The 8 speed Alfine is robust.
Three speed Sturmey-Archers were good for at least 50,000 miles 100 years ago. They’re probably one of the last non-consumable working parts on a bike. No magic, just plain simple good design properly built.
thepodge – Member
I can’t see a 3 speed hub being much lighter than an 8 or 11S-A 3 speed is 1,040gms, a S-A 8 speed 1,800gms.
fibreFree MemberThree speed Sturmey-Archers were good for at least 50,000 miles 100 years ago.
I’ve seen a few pre 50s ones still going strong in the past year. The date is on the hub if anyone is curious of the age of one. They did buy the contents of the factory and move it to Asia in recent years so they aren’t quite the same as they used to be, at least its still going though.
mick_rFull MemberI’ve got one of the new SA 3 speed hubs with disc mount and 135mm axle spacing. It takes a single cassette sprocket (not the old 3 spline sprocket) but still has the axle-end shifter cable.
Pros –
A bit lighter than an Alfine setup.
1:1 is true direct drive and very efficient (unlike Alfine which spins loads of cogs for 1:1).
The other two gears also feel very efficient and drag free.
Quite direct feeling (pawls instead of the roller clutches in Alfine so feels less mushy on power take-up)
Very nice thumbshifter
Cheapish (£100 all in)
Gear range is OK if used to singlespeed (one extra gear each side of ss for road and big hills).
Silent in gear 1 so not annoying when climbing really steep stuff.Cons-
Still a bit heavy.
No sealing whatsoever.
Cassette sprocket is still held on by a circlip, so need to fiddle with spacers to stop it being wobbly if using other manufacturer’s sprockets.
135mm spacing is achieved by a longer axle + piles of spacer nuts – bearings a long way inboard so axle might bend with heavier riders.
Due to axle spacing, chainline is a long way inboard – awful alignment with a regular ss chainring setup (e.g. Middleburn UNO). Alignment is bad enough to burst open half links or ss chain springlinks.
Nuts and anti-turn washers are nasty and low quality compared to Alfine.
Axle end cable roller thing is huge, heavy and might clip your heels – I went back to an old style Sturmey hollow nut.
Setting indexing is a bit of a guess.
If using old style hollow cable nut, it needs a cable stop in just the right spot on your rear stay.
Floppy slack cable in 3rd gear rattled against frame off road and could work loose.
Gear range not wide enough for big steep long hills (I tried and failed in Austria last summer….).
Incessant tick tick tick in gears 2 and 3 just like childhood memories 🙂So I’d say 50% of the way there, but needs improvement.
epicycloFull Membermick_r – Member
I’ve got one of the new SA 3 speed hubs…Agree with most of that.
When you say setting indexing, are you referring to adjusting the chain toggle to the mark? If so, no guesswork needed.
I got round the slack cable rattle by running the cable down the seatstay as in the pic. I rigged up a clamp on cable stop and adjuster from an old brake adjuster. You may be able to make it out in this pic:
There used to be a cog with 2 sets of ratios you could get for the hub. That way in Alpine terrain or when doing loaded touring you could slip the wheel forward and use the larger of the rear cogs – obviously you had to stop to do this. 🙂
My 60+ year old Humber has a 3 speed on it, still with the original cog in the oilbath chaincase. Its first owner had it 30 years and commuted on it. The next owner had it for a similar period before I bought it and he used it regularly. The mileage it must have knocked up is pretty big, and yet the gear change is still clean and precise.
BruceWeeFull MemberWhen you say poor sealing, just how bad are we talking? Re-grease every ride bad?
I’ve completely had it with rear mechs. They just dangle there attracting the attention of every rock and root like a dripping nipple to a hungry angry baby.
God help you if you bend the rear mech hanger and try to shit into 1st gear a bit quickly. Fecked mech, wheel, and if you’re unlucky fecked frame.
As far as I can tell the options are Alfine, SA, Rohloff, and Sram. So far I’m 90% certain I’m going with an Alfine 8. Some good deals around at the moment.
bencooperFree MemberRolhoff want it back to do a service, that’s sending a hefty bit of kit back to Germany
I’ve done hundred and hundreds of Rohloffs almost since they started making them – first one I sold was number 300-odd – and I can count on one hand the number I’ve had to send back to Germany.
And if I discount hubs that had to go back because someone at another bike shop did something stupid*, that number drops so low I can count it on one finger 😉
*A favourite was trying to bodge the sprocket removal tool and stripping the teeth on the sprocket carrier.
mick_rFull MemberI love the description Bruce!
SA sealing is non-existent – just pressed steel labarynth washers – you can almost see some of the balls. I’ve only run it in the dry as convinced it wouldn’t last a UK winter off road.
Did an oil bath soak on an original Alfine 8 and it was still very clean inside.
Epi – the long axle means I’m using a very long toggle chain (that came with the axle end roller thing) with a very old tube nut I had lying around – so toggle chain does not line up with anything on the nut.
The thumbshifter is like a regular derraileur one rather than old style toggle shifter that had a funny overshift feature. The cable has to be quite slack in 3rd gear to be able to get the thumbie to go into first. If it is only slightly slack in 3rd, then there is too much cable tension to click lever into detent for 1st gear (if that makes any sense).
I’ve made 2 frames with a cable stop silver soldered in just that position on the seatstay 🙂
Will try and post some hub pics tonight.
BruceWeeFull MemberJust orded an Alfine 8. It should get a fairly heavy workout since my plan is to fit it on my Dialled Alpine and then take it to Åre bike park for some red and black run fun 🙂
ir_banditoFree MemberRolhoff want it back to do a service, that’s sending a hefty bit of kit back to Germany.
When the bearings in my Rohloff started to go a bit slack (ie felt like the cones needed tightening, if it were a cup-and-cone hub), I took it to my LBS.
They sent the wheel to Ison in Cambridge.
Ison sent it back to Rohloff
Rohloff fixed it and sent it back to Ison, who sent it back to my LBS.Bear in mind it was bought second-hand and I had no proof of purchase or warranty.
It cost me nothing. Took about a week start to finish. and Rohloff included a letter apologising for the fast that their product had failed.
Can’t say fairer than that really.
thepodgeFree MemberI notice that a huge chunk of the hire bikes at llandegla are now running alfine setups
paul4stonesFull MemberWhen the bearings in my Rohloff started to go a bit slack (ie felt like the cones needed tightening, if it were a cup-and-cone hub), I took it to my LBS.
Shame there’s no LBS any more 🙁
mick_rFull MemberFor the Sturmey curious, I took a few (bad) photos last night. Apologies that everything is a bit dirty / garage is a mess 🙂
I also mocked up the Sturmey cable run I use with the tube nut (couldn’t be bothered changing wheels for the photo). My 29er has 16″ chainstays, so the big lump of Sturmey guide roller, bracket, plastic cover etc would clip heels.
[img]https://lh3.googleusercontent.com/-lrLFbCs1Y4Y/UZXYfF4dRgI/AAAAAAAAAEs/1zvy5Jl19N4/s640/IMG_1846.JPG[/img]
For the Sturmey curious…Maybe you should get a new indicator chain to match your axle length and the nut you are going to use. Then it will be easy to adjust your hub. It’s important to get it right because it the teeth aren’t fully meshed you risk damaging the internals.
Try SJS Cycles if your lbs can’t help/doesn’t know.
Or get your lbs to put you on the phone to the distributors for S-A. There’s a guy there who knows what fits what.
Edit: BTW there is now a shifter which attaches to your seatpost. Ideal for singlespeeders who don’t like cables dangling all over their bikes. 🙂 (SLS30-P or HSJ993, 27.2mm post)
droflufFree MemberEdit: BTW there is now a shifter which attaches to your seatpost. Ideal for singlespeeders who don’t like cables dangling all over their bikes. (SLS30-P or HSJ993, 27.2mm post)
But then it wouldn’t be singlespeed 😀 😯
But I get what you mean
bigmountainscotlandFree MemberIf anyone is buying an Alfine 8 (or you want to upgrade your existing set-up, I’d recommend the newer shifter
Fair bit sleeker than the original chunky beast and has dual release (2 way action) on the finger trigger. Still the reverse of a conventional shifter though.
The topic ‘Amazing Alfine? Or not?’ is closed to new replies.
