ok, here goes, do your worst STW:-
frame :2010 Ibis Mojo HD size large in bare/matt carbon fibre
forks :2013 Marzocchi 55 rc 3 ti fork – service a couple of months ago
Shock : 2012 Cane creek double barrel air shock
Brakes : 2012 Shimano Xt, with 203mm hope floating rotor on front and 180mm hope floater on the back
Front wheel : 26″ light bicycle carbon fibre 33mm AM rim, on hope pro II hub, hans dampf 2.35 tyre tubeless – bearings replaced last month
Rear wheel : 26″ light bicycle carbon fibre 33mm Downhill rim, on novatec hub, hans dampf 2.35 tyre tubeless – new wheel in august
Cranks : shimano SLX
Chainring : Ethirteen 32 tooth narrow wide
Cassette : Shimano XT with one up 42 tooth range expander
Derail : Shimano SLX shadow + 10 speed
Shifter : shimano XT
Bars : Renthal fatbar lite carbon 740mm
Stem : truvative 50mm
Headset : Cane creek angleset
Seatpost : rockshox reverb 125mm drop
Saddle : Fizik gobi, or I might change this before I sell it.
All mechanically sound, no play in bearings,bushings,headset etc.
