Been lurking for a while, using the forum as a resource for a pretty steep learning curve.
Treated myself to a new bike (first one in 32 years!) and thinking of going tubeless. The only downside i can see is not being able to run different tyres for different days/surfaces/weather conditions etc. British weather and terrain can be changeable and running the same tyre combination every day (even in the summer) doesn’t make sense to me.
The best solution for me would be to have 2 sets of wheels.From what I have read, keeping the hubs and cassette the same would only require small adjustment when switching over, which I don’t mind. Is this correct or are manufacturing tolerances so loose that even “identical” setups need major adjustment
Sourcing the sram 10 speed cassette is no problem to find but my hubs are not made any more. They are Sunn UN/Elitis SL I believe (although not badged that way).Does anyone know a source for these/ have some lying around/ found some on the web? If not, are there alternatives which will give me a better chance of achieving an easy switch over.
Am I overthinking this? Are all components set to run 475mm and 500mm chainlines etc and lining up brake discs etc is simple.
I know that this has been touched on before but no definitive answer seemed to come of it. Basically is it worth doing?
Thanks for reading.
