I have just taken delivery of a pr of 650c wheels for my old school TT bike.
There is something odd about the front wheel lacing. Its meant to be radially laced, but the spokes leave the hub at a slight angle that puts them approx 1 rim hole away from radial. So, they are very slightly tangential, but not enough to cross.
Is this ok? It looks odd and i def havent seen it before…..
I’m struggling to visualise this – pics? The only way I can think it could be done is if the spoke on one side of the wheel angle one way and the other way on the other side, so the tension in a pair of spokes on either flange balance?
Wouldn’t work, the hub would just untwist if all the spokes on each side faced the same way (and all on the other side the other way) with the hub ending up at an angle. [edit] how the flip does that wheel stay as it is? When building them up I get to that stage and the wheels a flopy mess?
I’m guessing the spokes are in parallel pairs like they are in a normal wheel, but due to a low spoke count they don’t cross. e.g. if you tell the calculator you’re building a 32 spoke 1x wheel then only use half the spokes you get a 16 spoke wheel with no crosses.
Can’t think of any benefit, other than maybe the builder had some spokes lying around the right length.
Posting an Image
The image must be hosted on the internet somewhere.
If it is on your computer you must first upload it to a photo hosting site. Try a search for image hosting to get you started.
Once you have chosen the image you want to show on the forum you need to find its URL (universal resource locator – its location on the internet).
imagelocationDo this by right clicking on the image and choosing “copy image location” (or similar wording depending on your web browser). Note that this must be the location of the image itself, not the URL of the page it is on.
Then go to the forum and type :
Where ‘http://www.singletrackworld.com/common/logo.png’ is the URL you just retrieved.
If you are linking to an image that you do not own copyright on then you must link back to the originating website by adding the
Flickr follows the same rules as above but they have added a button to retrieve the BBcode.
?Find the photo you want on flickr
?Above the photo there are two boxes “actions” and “share this”
?Drop the menu in “share this”
?See “grab the HTML/BBCode” and click.
?See two buttons below the script, “HTML” “BBCode”
?Check “BBCode”
?Paste this code into the Singletrack forum post box
Agree, you generate a torque across the hub shell, but it won’t be that great and the forces in the hub, spokes and rim would be statically determinant, as the pics demonstrate. Also agree I can’t see a benefit, other than increasing the shear area along the line of the spoke through the spoke flange, but it’s marginal at best at the OP’s spoke angles.
From the pics, kind a looks like the builder bought the wrong size spokes and came up with a way to use them/plough on regardless 😉
– if you asked for a conventionally radially laced wheel then its wrong
– if they’re 2nd hand and were built that way deliberately then it’s unusual*
It’s unlikely to explode and kill you in a fiery death crash, well, no more likely than any other minimally spoked un-crossed wheel anyway 😀
Personally I wouldn’t build one like that, but that’s more because I don’t think it achieves anything other than perhaps using up a stock of odd length spokes, but I would happily ride it, but if it was new, and I’d ordered a conventionally radially laced wheel I’d be sending it back, because they’ve either failed to tell you that it wouldn’t be (or why they chose to lace that way) or they made a mistake.
My understanding is building with the spokes coming off the flange tangentially, as they do in crossed wheels, means less likelihood of flange failure as the force is running across the flange face rather than trying to rip the spoke straight out of the flange. A poor description, but hopefully you know what I mean.
That’d be one reason for that ‘fallon’ pattern, effectively it’s a one crossed wheel but with the cross working over the two flanges rather than 2 adjacent spokes.
In the OP’s example however, I reckon that shallow an angle wouldn’t make any difference.
edit – if it’s bankrupt stock, presumably that’s a business seller, in which case I think you can just send it back under the distance selling regs. You may well be liable for the return postage though.
I now have an ebay seller insisting that because the spokes dont cross they are radial! Joy!
Fight the corporate machine, never surrender!
Although TBH, it’s probably added a tiny immeasurable smidgen to the weight, possibly made the hub flanges a bit more reliable. So I’d just get on and ride it.
Looks to me like they’ve attempted to lace it radially, but got the spokes in the wrong order.
2121 instead of 1212 as it were… Not sure how best to explain, but the effect would be that one side is radial, but the other is off set – a kind of half fallon.
It’s just ‘fallon’ – both sides look like they’re the same angle off radial. I suspect in reality though that it’s been build with slightly too long spokes. I can’t say it’d bother me any more than having a radial wheel in the first place though 🙂
