butterbean – Member
plus, your running a guide? it doesnt look so in the pic? ditch it sir! you dont need it
Ah, the voice of an XX1 (or XX1 style chainring) newbie.
Every single bike we have with XX1 & X01 has a guide (top admittedly, but that’s all you need) because it may work great to begin with, until wear is introduced into the system. Then it’s not very good.
There is a reason why SRAM changed the wording from ‘definately no guide needed’ to ‘a guide may be needed in some circumstances’.
erppp well ive used it for 2 months now, 3 times a week up peak district with every ride over 2500feet of climb minimum (usually around 3500-5000feet weekends, with descents that follow), so its had a lot of chainring wear useage and its no different now to when i had it new…..ive checked the chainring itself and the thickness of the wider teeth still appears to be noticeably thicker than the normal ones, so i think ill take me chances thanks!
like i said in a previous thread some of you must be riding gods riding full on downhill tracks ALL the time to be losing the chain!
i only usually get about 6 months out of a hope chainring up front, so im at least a 3rd into that now, with absolutly no difference in performance from new
if it fails after 4-5 months then i still think its worth it personally, its a revelation having no guide on
