Anyone had this before , before i go investigating
Basically gf commuting day one versa came home today complaining of noisy gears
Its not been adjusted by her since i set it up
However it seems like the cable inner has got shorter ….. With shifter set with all cable released the shift arm at the hub is in gear number 2 no amount of adjusting the barrel adjusters gets it close
Obvious solution is to adjust the cable to suit but i know it hasnt been adjusted at all ( not even a puncture )so cant work out why its all to pot.
Anyone any ideas ?
