Check the cone bearing, parts 25 and 34, they may feel ok but need to a fraction on the tight side of correct when spinning the wheel.
Part 26 is the drive side cover that seals the axle, which can get damaged from loose cone bearing.
Check part 26 for tightness, there is a tool to tighten and loosen this part but if you can unscrew by hand it is too loose.
If you can unscrew it check the seals and refit with a smear of grease on the seal. This temporary measure seams to have lasted for the last 12 months after an oil change.
I was going to replace part 26 if it still leaked as it fairly cheap.
Good luck
