The advert says it’s fluid but I thought fluid trainers relied on you changing gear/ pedalling harder to adjust the resistance. This one shows a cable and adjuster which looks like the ones you get on magnetic trainers.
I don’t know much about turbos though. I had a cycleops fluid 2 before and that had no adjustment apart from my gears. I have seen a few fluid/mag ones which seem to combine the two
Anyone know anymore about them?
https://www.aldi.co.uk/fluid-turbo-trainer/p/072257057135900
Also what others are recommended for around the same £70. It will only get used once week ish during the winter and could do with being fairly quiet as I will probably put a film on whilst I’m using it.
Last time I bought a fairly expensive one and didn’t use it enough so I sold it to buy a garmin with mapping which got me out riding more. This time I want cheap so I don’t mind it sitting there for six days a week not doing anything.
