Viewing 7 posts - 1 through 7 (of 7 total)
  • AirDrop Edit MK2 Owners – please help!
  • chrishc777
    I want to fit a 170mm reverb on my mk1, could someone with a mk2 send me a pic of the stealth routing exit? Christiandavid1989 at gmail.com
    Thanks!
    aazlad
    YGM.
    chrishc777
    Thanks Aaron!
    chrishc777
    Stealth routing now added to my mk1, 170 dropper is awesome!
    aazlad
    Happy to be of service!
    dizcostix
    Chris, can you share some pics please of your drill hole and cable routing – thinking of doing this myself!
    chrishc777
    Really simple actually, as long as you have a decent drill and bit.
    I drilled pretty much exactly where the mk2 routing is, just a tad offset as this meant I could get a better angle with the drill, and it also looks neater. Drilled out with a 3, then an 8 then with a 9 at a slight upward angle into the seat tube. Filed outside and in. Popped a Halfords wiring grommet in and fed the reverb tube through. I also drilled a small drainage hole in the bottom of the BB as whenever I take the BB out there is always sludge in there, guessing it’ll be worse with the new stealth hole. This is something that has been done on the mk2 and on most other bikes so I’m pretty confident it’ll be fine.
    There’s a better thread out there showing the process on a Shan. I didn’t need to bother taping and centrepunching though as the aluminium is quite soft compared to steel.
    Anyone who wants to see pics feel free to email me
The topic ‘AirDrop Edit MK2 Owners – please help!’ is closed to new replies.
