I had an AS-186 a few years back, they were a bit more expensive then.
The seals weren’t great and needing taping up, however, it worked reasonably well once sealed properly.
I would recommend getting a moisture trap for the airbrush as well as the one on the tank if you are spraying in the garage. When there is more moisture in the air (now) the single one on the tank will not catch it all.
I had this on both this compressor and the Iwata one I have now until I got a 2nd moisture trap.
Incidentally, the reason I got rid of the AS-186 was that I thought it was crap when all I needed was the additional moisture trap.
