Hi all, few questions if anyone can chip in…?
I’ve got an air fork, 100mm with rebound adjust. I weigh about 90kg.
I’ve set the fork to pretty much manufacturer guidelines, rebound set in middle, about 12 clicks from either extreme. Sag at 3.5 cm at a tad over 100psi. 103/105 maybe.
So a couple of questions/queries – I’ve done some reading around but still a bit muddled up…
Larger bumps feel fine although i’m only getting about 7cm of travel – is that normal, i.e. 2cm left in reserve for unexpected fails/big hits?
I should probably add the terrain I ride is at the more gentle end of the spectrum, trails and single track but not jumps and drop offs etc. deffinalty more xc than DH.
The other question is about small bump compliance and how to best set up for repeated small ruts etc.
I could use more sag, say 4-4.5cm? but with it bein an air fork, I understand the compression is non linier, and the fork gets stiffer the more compressed it is…so if im sat further into the travel, the fork would have the opposite effect and be less plush, as its partialy compresssed already?
Thanks
