Portable units are pretty crap as well, but they should see you ok for a short term fix, just get the correct size. They’re usually underpowered, so for your room (the room calc is about 2.5kw ‘standard’ conditions) i’d get something between 3 to 4kw & vent it properly. Just be careful that your electrical supply is suitible.
The feet in a bin of cold water may also sound bizzare, but it will also work 😀 as long as you can get past the ‘elf & saftey aspect!..
Thrustyjust- i’m not disputing that evaporative coolers work, they make sense for certain applications, they’re just not ideal for comfort cooling. 2 rooms at the same temp but with 2 different humidities will ‘feel’ very different. If thats all someone has then fair doo’s, but if they’re going to spend their money then they may as well buy something that would be more suitible for their needs.
In my experience anywhere thats got evaporative cooling for any sort of critical enviroment, have eventually also ended up putting in de-humidification.
