Ok so I stripped down my full suspension frame for a re spray.
I did the rear triangle 400 wet and dry paper 3 coats of rattle can later I was well pleased, so pleased the next day I did the same for the main frame.
I’ve ordered the decals and thought it would be good to put one coat of clear lacquer before I put them on then several coats after.
So I started in the main frame and then one part of the triangle. Ahhhh crackling!!! ( not the nice crispy eatable kind)
Not everywhere but enough.
What did I do wrong. It was all via rattle cans.
I’ve started to rub back the triangle and all the coloured paint was soft also so I’m going to leave it a few days to just flat back the crackling.
What should I have done different? Other than a professional re spray.
