Just bought a new digi box/recorder and am having trouble with the signal/reception. Initially I couldn’t tune all stations we’d previously been able to get, then I could intermittently get them. Changed my aerial lead from wall socket to box and seemed OK, but when I moved the TV and box to final position the reception went on and off. I checked all connections and found the lead plug to wall socket connection was a bit loose so as a temporary measure wrapped tin foil round the plug to make a snug fit. This seemed to work, until my wife was moving stuff to dust and picture went again. Bought a new wall socket and and plug is now a snug fit without tin foil.
I’ve remade connection to aerial in loft, been out and bought a new aerial lead and still intermittent reception. The strangest thing is that if I touch the body of the aerial lead plug the signal improves and can go from no picture to 10/10 on signal strength and quality, and on some stations I can change from no picture to 10/10 just by moving my hand to within 10mm of aerial plug/input socket at back of digi box without touching/moving anything.
I’m thinking faulty box now. Any other ideas before I take it back?
