The work on little smurfs bike continues…(Scott Spark 20 Junior) and I need to call on the advice of STW once again.
I’ve got 2 questions:
– On a frame that has v brake bosses, is it normally possible to remove them? The ones on the Spark look like you should be able to unscrew them – there are 2 flat sides on the boss itself (i.e. the bit the brake hardware slides onto) and if you flip the upper swingarm piece round it looks like the bosses have been screwed into a thread hole. Of course, I can’t the bosses out and I don’t want to potentially damage the frame by trying too hard if they aren’t meant to come out.
– I need to get the lower swing arm off the main triangle so I can check / replace the bearings and get the frame off to the powder coaters but I can’t work out how to get the pivot hardware out of the frame.
Removing a thin plastic dust cover on the pivot reveals (on each side of the bike) what looks like two round tubes of metal that have been pressed into the swingarm / main frame connection point. There is a 6mm allen bolt on one side…and this seems to tie these 2 bits of round metal together. Removing this bolt reveals a 10mm allen key style “hole” on the opposite side. Putting an allen key in this and turning either way results in nothing visibly happening.
There doesn’t seem to be much of a gap between these metal pieces to allow you to tap them out from opposite sides and I’m a bit stumped.
I can’t use photo hosting websites at work but I’ve taken some photos on my phone that I can email to anyone who would like to take a look and offer some advice.
Scott UK aren’t being any help at all.
Thanks all
