I’m converting to tubeless!
I’m using Eclipse Tubeless kit, DT 5.1 rims, Bonty XR4 tyres and Stans sealant
I’ve finally managed to seat the tyre onto the rim/tape using a ghetto accumulator. No way do I want to unseat it to pour the sealant in, so I’ve tried to get it in though the valve with the core removed. Problem I’m having is the nozzle on the bottle doesn’t fit into the valve, so quite a bit of the sealant is pouring out over the wheel (onto a conventient rag Ii had the foresight to put in place).
The bottle is showing about 2floz has gone, which should be enough for the tyre. Its sealed some holes, but not all, so I’m not convinced enough sealent has gone in.
What are you techniques for getting the white stuff into the rubber? (sorry, schoolboy humour)
