Read the BB cups, put them in the correct sides (they say on them which way they thread in). The frame threads will likely go before the BB ones will
68mm BB shell, frame mounted front mech, no chain device = 1 spacer on non-driveside, 2 on driveside
73mm BB shell, frame mounted fron mech, no chain device = 0 spacer on driveside, 1 on driveside
Add BB mounted front mech or chain device to in place of one BB spacer as required
Insert the BB cups BY HAND until against the frame. Use the tool to torque it then and only then
Cleaning the frame/BB threads and then adding copperslip helps put them in too
