Hi Neil
I’ve been running a 1×9 set up for about two years now and am just about to go to a 1×10 set up.
I’ve always run a 32t front ring but this is something that a lot of people don’t seem to agree with. I am never undergeared on any descent where I give a damn about how fast I’m going, which means to say that yes, it’s easy to spin out on long fire-road or tarmac road descents, but on those I don’t tend to give a damn; I am usually just tucked/resting. In the alps for instance, I’m going more than fast enough on those types of descent without having to pedal and everywhere else, I think you’d have to be a seriously good DHer to need something bigger than 32×11 (and by seriously good I mean competitive in at national Senior level).
Regarding chainguides; I’ve run the MRP 1×9, Gamut P20, E13 SRS and now run an e13 LG1+.
If you’re looking for absolutely the lightest guide possible (and you will need a chain guide – forget a front mech they don’t work) then the MRP 1×9 (or equivalent e13 I imagine) is the best choice. It will keep the chain on the top part of the ring but you will find the chain comes off of the lower part at the end of fast bumpy descents. That’s not a problem AS LONG AS YOU THEN DON’T PEDAL BACKWARDS!
I was finding that at the end of the downhill run, I’d backpedal to line the cranks up for riding away. When you do this, the chain derails from the top part of the ring and jams down between the backplate of the guide and the ring itself and it’s quite a faff to get it back on as you have to push the backplate away from the ring to free the chain.
If the chain has come off the bottom part of the ring, as long as you then pedal forwards, it’s fine and the chain just remounts.
For me then, the use of the LG1+ is less about having a built in bash guard and more about having a lower runner as well as a top one. This way the chain never comes off. But since I also use the bike for DH and alps trips, the integrated bash guard is also welcome.
The Gamut P20 is unequivocally the easiest bash guard to fit and set up and it seems to be compatible with a lot of different frame designs. The SRS was the older and much heavier version and though very good it’s more fiddly to set up. The newer e13 guides including the LG1+ are much easier to get set up.
