I’m after, in my view, the perfect front light. Requirements…
1. Run off AA’s
2. Flash mode that doesn’t go off, but alternates between low and high.
3. Flash mode that isn’t so bright it blinds people.
4. Enough max brightness for the odd bit of off roading, not after flood lights, but something that can hold its own on an unlit tow path and maybe the occasional bit of single track.
The ones that spring to mind are the hope vision 1, and the dinotte’s range. I’ve got a Dinotte 200L, which has just failed after years and years of solid service. Its going back to be fixed up, but will be away for long enough to warrant buying something else. The 200L, is almost spot on in every respect, and I’m tempted buy the XML-1 (its updated brother).
Anything else out there I should consider?
