Sharkbait has pressure and flow rate confused. The boiler will require a minimum pressure of 1bar or so, depending on the model, but the flow rate and temperature from the taps is interrelated win the power of the boiler and the groundwater temperature.
So setting the water temp on the boiler to max just means that you can get the most energy from the boiler – I.e. The highest temperature for the flow rate you demand for the taps.
Most combis have a flow limiter to regulate the flow rate to ensure a reasonable temperature is obtained, but the bottom line is leave the boilers hot water setting to max, and try not to be too impatient when filling a bath 🙂
