Viewing 6 posts - 1 through 6 (of 6 total)
  • A reverb of glacial slowness
  • ceepers
    Just picked up a second hand reverb bargain. It works but returns incredibly slowly even with the speed adjuster at maximum.
    I’ve lubed the shaft and checked the seat collar tightness and air pressure. Is Bleeding it the next step?
    kendo954
    Yep a bleed would be my next move (250psi ok first?)
    Shortened my hose the other day, very slow return, I just blead the remote and it was perfect
    ceepers
    Bleed kit ordered! Cheers!
    dirtydog
    Last bleed should be done with speed adjuster in slowest position.
    NorthCountryBoy
    Where’s the speed adjuster???
    kneebiscuit
    Its the silver bit where the remote joins the hose. It twists.
The topic ‘A reverb of glacial slowness’ is closed to new replies.
