Just bought some pikes and i want to make sure they're working properly so a few things to check:
1. They have no air in at the moment but when pushed down to bottom out they bottom out before the seals actually touch the very top of the stanchions (about 1cm before), is this normal or are they not getting the full amount of travel?
2. The blue compression adjuster doesn't seem to be seated quite properly and wobbles about a fair bit up and down
3. There is a bit of oil coming out of the compression adjuster
As i said before, basically checking if these are in normal working condition or if these are major problems that need to be sorted out
