Hey all, I have a few bits of clothing and an entire photography kit to sell. Please don’t make me put it on Ebay!
Fox Top, was ¾ length sleeves but professionally changed to normal short sleeves by my mum! Size medium, in good condition, no rips or pulls. £12 posted.
http://img84.imageshack.us/i/img1704r.jpg/
Sombrio long sleeved top, Hockey style, Medium, good condition, £12 posted.
http://img412.imageshack.us/i/img1705xk.jpg/
Dirt T shirt, Small, brand new and never worn. £10 posted.
http://img535.imageshack.us/i/img1703wq.jpg/
Giro Xen, Digital Camo pattern, barely used and like new. Size medium, £20 posted.
http://img5.imageshack.us/i/img1700az.jpg/
http://img249.imageshack.us/i/img1702v.jpg/
Now on to the camera kit. Its all used but has all been well looked after, is clean and works. I will do discount for packages, please email me with details of what you want and I will work it out for you.
Canon Eos 100 film body with body cap, manual (not pictured) and original strap, Ilford film retrieval tool and 14 films. I wont split this as its not worth selling individually. All in good condition and the body works well. I’ve shot approximately 10 films through this and not had a problem. Great for a starter as basic 28-80mm lens’ can be bought on Ebay for £30. £25 posted or £40 posted with the box of films below.
http://img593.imageshack.us/i/img1707c.jpg/
Box of 19 better quality films. The kit comprises of 4 Sensia 400's, 6 Sensia 200's, 2 Velvia 100's, 1 Velvia 50, 1 Neopan 100, 1 HP5 400, 2 Delta 3200's and 2 Delta XP2's. £25 posted for the lot.
http://img199.imageshack.us/i/img1709e.jpg/
Manfrotto 790B monopod. Designed for lighter Dslr’s and prime lenses. Never used! £20 posted.
http://img209.imageshack.us/i/img1712a.jpg/
Hoya 77mm Circular Polariser, like new. £20 posted.
http://img510.imageshack.us/i/img1714e.jpg/
Cokin set comprising of two 58mm adaptor rings, one 77mm adaptor ring, Cokin mount, a P121 graduated polariser, two P121M graduated polarisers, one P197 graduated orange Sunset filter and one P164 Polariser. I wont split this kit as Ill be left with odds and ends. £30 posted for the lot.
http://img8.imageshack.us/i/img1715h.jpg/
Canon EOS 50mm F1.4. A cracking sharp quick lens. If I could have just one prime lens, it would have to be this one! USM focus motor, sharpest I’ve found at F1.8/F2.0. Comes with front and rear caps, UV filter and suede bag (not pictured) I cant find the box or instructions for some reason. Lens is in mint condition, focuses properly, no dust in lens or scratchs on elements. UV fitted from brand new. £200 posted.
http://img717.imageshack.us/i/img1716k.jpg/
http://img152.imageshack.us/i/img1718b.jpg/
http://img209.imageshack.us/i/img1719zm.jpg/
Jessops 2 x converter. Cheap basic converter but works well enough. Includes box and bag (not pictured) £20 posted.
http://img13.imageshack.us/i/img1720a.jpg/
Canon 580EX II Speedlite. Has been brilliant, never missed a beat. A few scuffs on the body but no damage. Complete with bag, stand, box, instructions, warranty card and 3 packs of new Lithium batteries. £260 posted.
http://img263.imageshack.us/i/img1724i.jpg/
http://img522.imageshack.us/i/img1722fn.jpg/
http://img38.imageshack.us/i/img1725db.jpg/
Canon EOS 24-70mm F2.8 ‘L’ series. Made using Fluorite glass for me it was an easy choice. Great lens, best at f3.5/F4 but still better than most at F2.8. This was my main lens that stayed on the body most of the time. Lens condition is good, zoom ring is slightly loose but not bad enough to pull it down under its own weight. Lens hood has scuffs from being used but again the elements of the lens are perfect, no dust inside and the lens focuses well with the USM motor. Front and rear caps, UV filter (UV filter might need replacing at some point as this has marks on it) original bag, box, instructions and warranty card. Again, UV fitted from new. £750 posted.
http://img375.imageshack.us/i/img1726wh.jpg/
http://img560.imageshack.us/i/img1727h.jpg/
http://img3.imageshack.us/i/img1728a.jpg/
Elinchrom Skyport Universal Trigger set, barely used. Includes loads of extra connections, straps and loads of replacement watch batteries for the trigger. Great condition, packaged with instructions and all packaging. £80 posted.
http://img441.imageshack.us/i/img1729a.jpg/
Joby Gorillapod SLR ZOOM with the Ball head, £30 posted.
http://img28.imageshack.us/i/img1730p.jpg/
Canon 40D Body. This has been mine for the last 2 and a half years, and Ive loved it. It still holds it own against the newer EOS cameras. 6.5 frames a second, 10.1 megapixels, 3200 ISO max, magnesium frame and dust sealed. Spot on colour reproductions, slightly warm as all Canons are, Great noise control up to 1600 ISO. This one has shot approx 12,000 frames, which isn’t alot as they are tested to 50,000 actuations. I have all the box and instructions, all cables, charger, body cap, two straps (original Eos strap and an Optech padded strap) 3 genuine Canon batteries, Hahnel wireless remote and some LCD protectors. Body is in very good condition, a few off scuffs but no damage, dents or broken bits. Everything is solid, clicks and moves well. The LCD has had a screen protector from new and although is scratched is doing its job. I would like £350 for all this posted. £380 with the 16gb Sandisk Extreme card.
http://img204.imageshack.us/i/img1731u.jpg/
http://img836.imageshack.us/i/img1732t.jpg/
http://img502.imageshack.us/i/img1734iz.jpg/
http://img534.imageshack.us/i/img1735v.jpg/
http://img703.imageshack.us/i/img1736p.jpg/
Lowepro Mini Trekker AW rucksack. Has been carrying all of my kit around for the past year. No marks, rips or tears and is clean. Plenty of ingenious space, a flap in the front for your tripod too. I paid £59 for it and Ive kept the receipt so the new owner can carry on the lifetime warranty. £40 posted.
http://img831.imageshack.us/i/img1738v.jpg/
http://img191.imageshack.us/i/img1739o.jpg/
http://img211.imageshack.us/i/img1740s.jpg/
Cleaning bits, soft microfibre cloth, rocket blower and lenspen. £10 posted.
http://img203.imageshack.us/i/img1741se.jpg/
Interfit 5 in 1 reflector in bag. £10 posed.
http://img156.imageshack.us/i/img1742q.jpg/
Martin evenings Adobe Photoshop CS2 for Photographers book and a Portaflash studio flash techniques book. £12 posted for the Martin Evening book, £10 for the Portaflash book.
http://img708.imageshack.us/i/img1743zu.jpg/
Lowepro CF card holder, like new. £8 posted.
http://img202.imageshack.us/i/img1744uu.jpg/
Aluminum flight case measuring approx 11.5 inches tall, 14.5 inches wide and 5.5 inches deep. Scuffs and marks, no dents, no keys, but small enough to go into a luggage holdall on a plane. £20 posted as its heavy and bulky to post.
http://img197.imageshack.us/i/img1745o.jpg/
http://img833.imageshack.us/i/img1746un.jpg/
Camlink TP PRO28B tripod. Adjustable joints, aluminum legs, clips to pull the legs wider to get it lower, adjustable rubber feet with wind out spikes, removeable head, two plates with the head, hook underneath for weight, centre column can be reversed for taking photos upside down. 30 inches when closed, maximum height of 67 inches. This is built as sturdy as a Manfrotto without the price tag. Includes bag. £50 posted due to weight.
http://img600.imageshack.us/i/img1748v.jpg/
http://img69.imageshack.us/i/img1749pw.jpg/
Manfrotto 804 RC2 3 way head. Solid and very smooth. Barely used so like new. One plate. £40 posted.
http://img155.imageshack.us/i/img1751r.jpg/
http://img443.imageshack.us/i/img1752ky.jpg/
The whole lot at that price would cost £2040!! If you wanted the whole kit Id drop it to £1800. As I said, Ill discount bits for packages if anyones interested.
Doug – dooge_uk AT yahoo.com
