The largest size in a single dimension I could find is 50cm, which won’t be enough diameter for a 55mm wheel, you could always make two halves from (50x100cm) and then tape them with two seams (I plan on a cone with just the one seam, sealed with Gorrilla tape). I will remove just enough central hole to be a tight fit on the hub, tape drive side internally to spokes, and rim, and tape NDS to just the rim.
There is a site on ebay that will sell you ready cut covers for about £30, which might be more cost effective.
EDIT: And the single biggest change in my position to much more aero has come from fitting a forward (actually a reversed Thomson layback) seatpost and shorter saddle. This rotated me forward to a position not attainable on a road bike with typical geometry.
