Hello,
I have just replaced the chain on my bike as it was showing .75% wear. I check my chains weekly, keep clean and lubed etc.
When I went for a spin I started to get jumping from the chain when I was in the big ring using the largest sprockets at the back, not the largest as I don’t cross chain but the 3/4/5 and whenever I came to put power down hard the chain would jump off the front chainring onto the crank arm.
I checked the FD alignment and it’ fine and the gap between the fd and chainring is as small as it can be.
I’m coming to the conclusion that it’s a worn front chainring but it has only done 7600 miles which I think isn’t too great for a 11 month old Ultegra 6800 unit.
I run a full Ultegra Di2 setup and look after it meticulously. The cassette is 4k old but it’s in good condition having never been run with a stretched chain.
I have tried the chain slack test lifting it up whilst on the rings and there is pretty much none. WHat do you guys think of these chainrings?
[img]https://farm5.staticflickr.com/4644/25543204458_0650161a89_k.jpg[/img]
[img]https://farm5.staticflickr.com/4593/38534936615_aa8ae2b920_k.jpg[/img]
