Viewing 40 posts - 161 through 200 (of 214 total)
  • 62 points and still on the road
  • captainsasquatch
    That wouldn’t be difficult. Lend me a tenner?
    Cheque OK?
    molgrips
    If you’re shit at driving, the solution isn’t speed limits
    Speed limits AND better training.
    We will always need limits. People will always think they are better than they are, but more importantly we need consistent behaviour on the roads.
    Cougar
    No. Better training AND speed limits.
    I’m not arguing against limits for the reasons you suggest, I’m arguing that the priorities are arse-backwards.
    thecaptain
    Better training won’t stop dicks being dicks. And it’s dicks that have and cause the most accidents.
    squirrelking
    I mean a stationary object at the limit of your line of sight. Obviously. But why engage brain when the usual sarcy comments can be rolled out.
    This has been said numerous times but is always pissed on. It’s the whole driving to the conditions point – it might me safe to do a ton over Rannoch Moor on a dry day with full visibility but forty round a sharp bend further up is way too fast. You could find cyclists or a broken down car on the road. But hey, you weren’t “speeding” when you hit them.
    Molgrips- same people who will get dogmatic rather than look at something dispassionately.
    nealglover
    It was a genuine response to your simplified explanation.
    There is No point making something “simple” if it’s completely ambiguous.
    But feel free to criticise someone pointing for out your errors.
    Be aggressive and dismissive too if it makes you feel better.
    sbob
    mrlebowski – Member
    The reason there is so much focus on speed..
    Is that it’s one of the easiest ways to reduce RTC’s & improve road safety.
    What bollocks! 😯
    Speeding counts as primary causal factor in 4% of KSIs, so you’re not addressing the cause of 96% of serious accidents.
    Putting a plaster on a scratch on your forearm will do **** all good when you’re bleeding out of your femoral. 💡
    There is a straight line of decay of KSIs over the years, and increasing speed enforcement has had no effect on that straight line.
    How exactly did you form your opinion? It’s not one that can be concluded from the facts.
    kerley
    You have to accept there will be accidents when people are driving cars as people don’t concentrate when driving, drive too close behind each other, take silly risks etc,.
    Passing the driving test takes training and everyone has done that and if every drove exactly as they did on their test there would be far fewer accidents. But they don’t.
    funkmasterp
    As brought up in most other threads on this subject, I believe mandatory re-tests or refresher courses would be the place to start for improving driving.
    Serious negligent behavior that results in death should come with a lifetime ban. Minor infractions could fall under points / fine. The more serious, but not fatal incidents should result in a re-test with stricter parameters for passing.
    On top of this, five yearly mandatory refresher courses for driving and skill improvement would be implemented. It’s all moon on a stick, but would be better than the current situation. All in my opinion of course.
    mrlebowski
    What bollocks
    Charming…kiss your mother with that mouth?
    It was what I was told on my speed awareness course – yes, I’ve been knicked for speeding & far be it for me to argue with someone whose job it is to retrain drivers..
    You, on the other hand…?
    & I think you’ve missed the point of what I said.
    That being it’s the most cost-effective way of improving road safety.
    The most effective? I wouldn’t know..
    Might that have something to with cars being safer?
    Any proof that there is a direct link proving that speed enforcement has little or no effect on road safety?
    kerley
    Agree but how often would they have to be. How quickly do people start to drive badly after passing their test as would need to be at least at that interval. Monthly re-tests!
    squirrelking
    Neal, sorry, genuinely thought you were being facetious.
    funkmasterp
    I’d go for after two years for new drivers and then every five. Not ideal, but at least it would be proactive and maybe convince people to stick to a higher standard knowing that they have to, at some point, prove to an examiner they are still capable of driving. Perhaps make it random to keep people on their guard.
    My wife used to be an instructor and do advanced driving courses too. She says one of the most infuriating things was trying to instill situational awareness in teenagers. She’d spend time explaining why regular mirror checks, looking ahead, planning ahead and being extra cautious in residential areas are paramount. Only for the kids to arrive at the next lesson spouting “my dad says not to worry about other cars, nothing wrong with speeding to make progress” etc
    How do you tackle that? When kids are learning selfish, idiotic behavior at home.
    br
    When you want to overtake a slow moving vehicle on a single carriageway road, you see a gap, you think ok that’s enough space, and you go. If someone comes screaming around the corner at 100mph, suddenly you have far less space than if someone came at 60.[/I]
    I taught my sons to always consider that when thinking of overtaking, is there enough space for them to do it safely if I was coming the other way.
    The most dangerous part of the road, is the other side.
    Mol
    The Police’s only role is to enforce the rules, Parliament makes them and councils/departments implement them.
    br
    I’d go for after two years for new drivers and then every five. Not ideal, but at least it would be proactive and maybe convince people to stick to a higher standard knowing that they have to, at some point, prove to an examiner they are still capable of driving. Perhaps make it random to keep people on their guard. [/I]
    We’ve done this previously. It’s a 4 month wait around here for a test, and somehow you’re going to increase capacity 30-40 times?
    Approximately 1m people take the driving test pa and we’ve 45m drivers (own a licence).
    Also interesting that 50k were banned (in a year), so 1%pa.
    jambourgie
    Can’t believe the people pushing for retests. Do you want the cost and ball-ache of doing that? I don’t. Maybe for pensioners.
    From the moment you pass your test you should get better at driving. If you’re getting worse then either the test/training was too short/easy or you’re a moron.
    I also don’t believe that speed is the be-all and end-all. I think it’s generally about people being stupid. I’ve met so many otherwise book-smart people who genuinely believe that cyclists shouldn’t be on the road, will drive whilst texting etc. There’s something wrong with the training.
    I guess what I’m saying is that retests would likely be just a nice little earner. Like the education system that churns out straight-A students with the common-sense and creativity of cannon balls – people will just pay the fee and pass the retest. They won’t actually learn anything.
    mrlebowski
    There are many thing I don’t want the “ball-ache” of but making roads safer is hardly what many of us term a “ball-ache”….
    Why would they not be safer drivers?
    Why would they not learn something?
    jambourgie
    How about a re-test every day at 6am then? For safety like.
    mrlebowski
    Your facetiousness just undermines your point & strengthens mine.
    Thanks!
    funkmasterp
    As I said, moon on a stick. I definitely think the test should be more difficult and more involved. When my missus was teaching she had several conversations at various seminars regarding how lessons and testing need a massive shake up and fundamental changes. Some of the thinking applied to a different era.
    As for being a ball ache having to pay out and partake in re-tests / refreshers, that’d be part of the point. Yes it would be a ball ache, but that might help hammer home
    the importance of good driving.
    br
    As I said, moon on a stick. I definitely think the test should be more difficult and more involved.[/I]
    The Russian driving test is harder than ours, doesn’t seem to make a difference – maybe because it’s not the answer, just another ‘easy answer’?
    jambourgie
    I think a better initial training and test that includes a basic intelligence test, and a graduated development of road skills from cycling, through to motorbike, to car. Which would develop awareness and empathy for other road users rather than “I’m the king of the road in my little safety-bubble”
    funkmasterp
    What do you think the answer is? Genuinely curious about other people’s ideas and views, no matter how far out they may seem.
    That would be a great idea. Showing people what it’s like on cycle, motorcycle and progression from there would help build empathy and show people how vulnerable these road users are. Now we’re getting somewhere. Less arguing, more theories on improving skills 🙂
    whitestone
    I’m not sure that compulsory retesting at any interval is going to improve things – everyone genuinely believes that they are a better than average driver so why do they need to be retested? Maybe retest those with a certain number of points on their license.
    Perhaps different punishments: points on your license doesn’t seem to be working very well. A week in jail for every three points? Would cause pandemonium to begin with but a few high profile cases and people would start to get the message.
    Generally it’s the attitude/belief that once you get into a car you can do what you like with near impunity that needs to be changed.
    scaredypants
    I’d retest only those who’re involved in a crash or who get points above a certain level (I’m thinking 6-9 and then every time after that)
    and after a couple of times they’d have to pass an advanced type of test – and/or mandatory black box or something
    funkmasterp
    A combination of Scaredypants suggestion above and Jambourgie’s ideas regarding staged learning of different vehicle types would be great. It would initially reduce the number of road users due to the level of time and skill required and place serious restrictions on bad behaviour for those that are already on the road.
    This is key to it all really. It’s nice to see people partaking in this debate and putting forth ideas without it resulting in arguing and point scoring 🙂
    scotroutes
    Resulting in the depopulation of rural communities as young adults wouldn’t be able to get to/from education and employment. That’s the problem with all these good suggestions, individually they look great but the knock-on effects could be devastating in other, unintended, ways.
    FWIW I’m in favour of compulsory telematics and dashcams with tougher penalties.
    molgrips
    What? Who’s saying we should NOT drive to conditions? I’m certainly not. Let me be clear. Drive to the conditions, but no faster than the limit.
    I cannot believe you are advocating giving drivers free reign over how fast they go. That’s insane. Most drivers just aren’t that good. And no driver knows everything going on around him at all times.
    pondo
    Because by and large everyone is wrong, me included.
    Cougar
    That wouldn’t be too hard to implement, we already do it with bikes. Pass your test, you’re restricted to (say) sub-100PS vehicles. After two years you can take an advanced test to qualify for bigger cars.
    milky1980
    I am regularly assessed on the standards of my driving at work, together with the rest of my colleagues, it’s not like a driving test at all. It’s more akin to the test I did to get my C1 category, testing your wider observational skills, knowledge of the regulations and your reaction to situations. Has it made me a better driver? Definitely. Should everyone have to do something similar every 5 years or so? I think so, yes.
    To use your example of straight-A students, they may have the basic knowledge but need to be coached into how to use it effectively, pointing out any bad habits at the same time.
    I can’t believe we’re all on here arguing for/against further driving skills training when we are all generally happy to accept that the best way to get better at riding a bicycle off-road is to pay decent sums of money to spend a day with someone like Jedi! Make a mistake on your bike and it’s usually you who comes out worst, make a mistake driving and you can potentially kill multiple people. The culture of the car has skewed the priority of the population, even the cycling community.
    Cougar
    Why?
    If everyone drove to the conditions, the limits would be meaningless. The only reason to have limits at all is precisely because people cannot be trusted to drive appropriately to the conditions.
    jambourgie
    Not me.
    whitestone
    @pondo – a slight misinterpretation of what I wrote 😆 people believe that they are better than average therefore they don’t believe they should be retested.
    funkmasterp
    @pondo – a slight misinterpretation of what I wrote people believe that they are better than average therefore they don’t believe they should be retested.
    Makes it compulsory and personal beliefs on skill level don’t matter. There is always room for improvement.
    Are there any countries that do not have speed limits and if so does this reflect in accident and fatality statistics?
    That’s the frustrating thing. I fully understand your point of view, but there are too many individuals (zanelad from a few pages ago for example) that would just travel at ridiculously fast speeds irregardless of weather or road conditions.
    Public transport improvements, cycling, Mopeds, motorcycles, ebike etc. We have this weird, everybody should drive, culture that needs to be addressed for the sake of the environment if nothing else.
    scotroutes
    Public transport improvements; subsidised by the tax payer? Cycling, e-bike; not suitable for many journeys.
    Moped, motorcycle; are you suggesting these road users don’t require testing?
    Again, I’m not disagreeing from an environmental perspective but you’re still enforcing a centralisation of the population and that’s not only unrealistic but also undesirable.
    funkmasterp
    Sorry, I’m working on the Jambourgie staggered test approach whereby you have to pass muster on two wheels before four. Should have really outlined that.
    I’d be interested to know how many people pass their test and then just drive distances that are easily covered by other methods. I know a couple of people at work who only drive to work and back, to the shops etc who live within walking distance of both. Not saying they shouldn’t be allowed to, just curious as to what percentage of traffic on the road those sort of journeys are?
    br
    I’ve just been to the shops, about a mile away.
    Only other option is walk or cycle. It’s pi55ing with rain plus windy.
    Oh, and about 200 feet lower, so a climb all the way home.
    jambourgie
    I often use the motor to nip down to the shop which is 300m. But it’s the weather thing. In summer, I’ll happily wander down in my shorts, but I’m not getting all wrapped up to go out in the howling beastliness when I don’t have to.
    I also occasionally exceed the limit if appropriate to so, or the whim takes me.
    Ah, confession feels good 🙂
    In mitigation: In summer I barely use the car. It’s just that the weather doesn’t suit my clothes so I use the car in winter.
    slowoldman
    Then the evidence suggests there are many morons on the road.
    I’ve been driving over 40 years and haven’t had an accident in the last 30. Oh, apart from reversing into that bollard in a car park!
The topic ‘62 points and still on the road’ is closed to new replies.
