**** me, that was a looooong ride! 146.4km at an average of 19km/hr, 7hrs 45mins. All in all though, quite a nice day, though it's a bit unfair to have to climb over the South Downs after 130km+ of riding! The descent down to the coast was good though 🙂
Followed the South Downs Link until I somehow got lost, then did the last 17km or so on the road, hence it adding up to a bit more than the expected 135km or so.
Cramping up a little now, need to drink more water… carried 3 litres + a 500ml Powerade and 2 x 500ml 'For Goodness Shakes' wasn't enough really. Ate 3 bananas, 1 clif bar and 2 chocolate doughnuts, again probably not enough fuel?
My question now is, just how the **** am I meant to ride for 24hrs at MM??
that's what I was thinking on the train home, as I constantly cramped up in my left groin (got some odd looks as I massaged that one out!). I don't think I could've turned around and ridden all the way home, and that'd only take me to 16-18 hours (allowing for a slower average speed)… What's the trick to this 24hr solo lark??
If you're suffering with cramp, you need more salt. Replacing fluid is one thing, but you've also lost salts from your body, which then leads to muscle cramps.
Crisps, salty, peanuts, even just salt in water (eeurgh) will help. Don't be fussing with all those expensive 'sports' drinks; all they contain is stuff you can easily get from regular foods anyway. Marketing gimmick.
And if you're doing lots of exercise, don't fall for that 'eat less salt' bollocks; that's aimed at people who eat loads of processed junk. Salt is vital for good health, in the right amounts.
yah, just made myself drink a nice cup of salty sugary water, not tasty at all!
nowhere near enough food, about 5000kal that need to come from somewhere. carried too much water, there must have been somewhere to fill up half way? a Nun tablet or similar would have stopped the cramp.
Basically, starts in central London ('official' start point is the London Eye), goes to Roehampton Gate at Richmond Park, exits via Ham Gate and joins cycle route 4, this takes you all the way to the Wey River Navigations. You then follow the Wey all the way (ha ha!) to Guildford and then join the South Downs Link. You follow this for around 50km and then your meant to join the South Downs Way on to the coast, but I somehow cocked this bit up and ended up finishing off the last 17km on road (thank god for GPS, otherwise I would've been a little lost!)
Feeling a little knackered this morning, woke up with a killer cramp at 3am, had me in tears it did! Took half an hour to work it out, then drank some more salty/sugary water… shall have to concentrate more on electrolyte replacement on these epics!
Psychle, how 'tough' is this route? IE, would it be ok for someone with limited off-road skills (otherwise confident cyclist), and a dislike of 'bumpy dangerous bits' ( :roll:)? Or is it a bit demanding in places?
Is it officially 135km/84 miles? And is there some sort of guide? Ta.
not demanding at all (other than the distance), it's all flat towpaths and metalled bridleways until you hit the Downs, then it's uphill to get over them, but still on metalled bridleways (or on the road if you muck it up like I did!). There is a route guide, shall email it to you (Ratcatcher emailed it to me last year).
Joining the SDW from the Downs Link (not South Downs Link, sorry!) should be very straight forward, you cross the A283 just south of Bramber, then there's a little wiggly bit and it comes out at a field, you right up the RH side of the field, then there's a 90 degree left, with a path coming from the right, that's the SDW. You cross the Adur on a little concrete bridge, the Downs Link turns right, IIRC the SDW goes straight on there.
This sounds similar to the BHF L2B off road route of last year (in fact, may be the route?).
That was fun, but not technical in the least. Would have been better on a cross bike as the south downs link is an old railway line – not famous for their elevation those railways!
Elete water can be added to any drink and seems to ward off cramp very well. The trouble with Nuun/Zym is that you're only getting electrolytes, so need to take your carbs in other ways.
I've ridden the Downs Link (it's not called the South Downs Link) many times from Cranleigh – Shoreham and back, and to be honest I find it much more comfortable on a FS, even doing that on a hardtail tends to be pretty uncomfortable, personally I wouldn't want to do it on a cross bike!
Yep, 'tis the Downs Link, sorry 😳 It is flat but I reckon it'd be a little uncomfortable on a rigid or CX bike, the surface is a bit rough at times, bit like cobblestones etc. I did it on my ASR-sl (3.75" rear travel), was comfortable enough on it.
Good ride there mate but I to would have starved on the little food you ate.I eat every 20 minutes or so on long rides ,little and often ,fruit pies anything I like as it all gets burnt off during the ride .You didn't take to much water by the way I would use a large 750ml bottle an hour so would have used more than your bladder held on a long ride like you did
Posted 14 years ago
Viewing 37 posts - 1 through 37 (of 37 total)
The topic ‘34336 pedal strokes gets you from London to…’ is closed to new replies.
