- This topic has 155 replies, 66 voices, and was last updated 10 years ago by bigjim.
£1600 audio ethernet cable
jivehoneyjiveFree Member
but you can’t argue with maths.
Not to subtract from your point at all, but all things being equal, opinion is divided… and going by this thread, division is multiplying.
Feel free to come back at me if you have anything to add.
mimilovellFree Memberwhat type of ethernet cables are they? You can even get them made espcially for you, with the right ends and you can choose the cable. We got audio cabled made like that and it was cheaper getting them already made from the shops.
bokononFree MemberAdam, Mackie or JBL monitors are very accurate
All of them use reflex cabinet designs which are inherently poor at “accurately” reproducing the bottom end simply due to the design – you can do a lot to design out serious problems, but using a ported design is always going to incur at least some time based obfuscation in the bottom end as the signal from the port mixes with the direct signal from the driver.
Don’t get me wrong, I use HR824’s all the time and they do a great job, but they suffer – like essentially all speakers – from inherent compromises to the sound.
crikeyFree MemberYou’re not really doing this for the music are you?
I mean you’re not sitting there singing along because the song makes you feel good, or dancing around the room like nobody is watching?
No, you’re not.
You’re playing my willy is bigger than your willy, aren’t you?
Hmmm?
bigjimFull MemberAll of them use reflex cabinet designs which are inherently poor at “accurately” reproducing the bottom end simply due to the design – you can do a lot to design out serious problems, but using a ported design is always going to incur at least some time based obfuscation in the bottom end as the signal from the port mixes with the direct signal from the driver.
Yeah I’m definitely not saying they are perfect, just designed to bring the contents of the audio signal into your ears more honestly than a hifi speaker, which needs to sound ‘nice’, which seems to be doable in the pro-audio world for £1000 but not hifi, going back to the comment I was originally replying to. Having said that I’ve not looked at monitor prices for a good 5 years so they might have gone up a bit since then, certainly I think you used to be able to get a pair of mackie’s like yours, or Adams, for a grand back then.
bigjimFull MemberYou’re playing my willy is bigger than your willy, aren’t you?
no idea I’m just copying and pasting from KVR
bokononFree MemberI think you used to be able to get a pair of mackie’s like yours, or Adams, for a grand back then.
I have no idea how much they cost, other people equip the studios, I just use them.
chiefgrooveguruFull MemberOK I was generalising quite a bit in a very short answer and I guess there is a bit of interpretation in the word accurate. I’d certainly agree with you saying monitors are designed to show every element of the recording/sound they are reproducing, without flattering the audio to sound ‘nice’ at all, but that is what I personally would call an accurate reproduction of the sound, whereas the hifi sound I would say is designed to flatter the sound, and sound as pleasing as possible, rather than show up every bit of sibillance, 400hz mud, aliasing, etc etc that is present in the actual recording and audio signal being turned into sound. As you say the point of the monitors is so you can hear everything that is there in the audio signal, and that is what I would call being accurate.
This is one of the myths of hi-fi which the industry uses to keep people buying hi-fi speakers rather than often superior active monitors for similar cost. Once you’ve bought active speakers it’s much easier to break the endless upgrade cycle because you have amp/crossover/loudspeaker all in one unit which is designed to work together.
Until I started designing loudspeakers I had no idea quite how far from truly accurate a good hi-fi loudspeaker is. But accurate is good! The biggest problem in hi-fi is not achieving flat frequency response but managing that whilst also achieving excellent polar response (dispersion), dynamic response and transient response (timing) and very low distortion (of which there are many contributory mechanisms). Get that right and you’ve made as good a loudspeaker as is possible. It’s the polar pattern that is the killer with hi-fi speakers – that’s why they struggle to sound real with acoustic, orchestral or choral music.
My old hi-fi speakers are pretty rubbish but I still love good music on them – though I have some much much nicer components waiting to be measured and have crossovers and enclosures designed and built when I get a moment. Maybe I’ll measure them tomorrow as I was testing a new quasi mass-loaded transmission line enclosure today so everything is set up and calibrated!
One upside of getting into loudspeaker design was discovering that when it comes to speaker cable you’d be very well served by standard 13A mains cable! 😛
bigjimFull Membernew quasi mass-loaded transmission line enclosure
you lost me at new!
RustySpannerFull Memberchiefgrooveguru – Member
Can you tell the difference between different types of speaker cable in your home setup?
CountZero – Member
And cables?
Pah! Voodoo, innit.Well, I can tell the difference between solid core and stranded speaker cable quite easily and my hearing is knackered. 🙂
oldboyFree MemberI have a relatively expensive Nordost digital interconnect cable between my streamer and DAC/preamp, and guess what? It sound about the same as the cheapo cable it replaced, and I have ears like a bat! (Well, only in appearance terms :-))
TheBrickFree Memberneilsonwheels – Member
Are they directional.?[video]https://www.youtube.com/watch?v=12GHUf8DOPs[/video]
chiefgrooveguruFull MemberCGG who do you work for?
It’s not something I’ve experimented with in a very long time but I feel once you’re getting into expensive cables amounts of money you should be going active anyway!
RustySpannerFull MemberSo is that a yes or no? 🙂
Surely you conducted listening tests before coming to the conclusion that:
chiefgrooveguruFull MemberI’d need to get rid of the electrolytic caps in my home hi-fi speakers before a listening test on cables would have value! 😛 13A mains cable has very good DCR, inductance and capacitance for most loudspeakers if the runs aren’t extremely long.
RustySpannerFull MemberSo that’s a ‘no’ then is it?
And why would a cable comparison have no value?
bigjimFull MemberCan you tell the difference between different types of speaker cable in your home setup?
Can anyone, genuinely, double blind yada yada, as long as the cable is able to carry the current required and not long enough to cause problems from resistance yada yada?
ask1974Free MemberJust answering a couple of points raised with my earlier post…
This is classic meaningless diversionary twaddle.
Come up with some measurable effects that those cables produce and you will have us, otherwise it’s just marketing bollocks.
I was referring to a complete ‘system’ rather than cables themselves so went a little off topic. However it’s a pertinent point when doing blind or open listening tests. Aspects such as sound stage and imaging are not ‘measurable’ however I’ve found them to be a very good means of discerning the improvements (or not) offered by different system configurations. Yes it’s subjective but having spent years in the retail environment and done thousands of demos it has always proved to be useful for clients.
Cables can very easily change the tonal character of a system and the cable manufacturers capitalise on this,
Really? What happens to the electrons in a $200 interconnect compared to a $20 interconnect that makes such a difference?I’m not going to be drawn too much on this but when I refer to ‘tonal character’ I’m not referring to quality but how bright, smooth etc. a system sounds. Whilst I’m firmly in the camp that cables have a placebo type effect in that quality is perceived rather than improved, we used cables to make minor adjustments to systems to tailor the sound to the clients ear. Minor as they were time and time again this process worked so from experience there was (and still is) some impact cables play. Cost of cable was never a serious factor though, just a well manufactured cable.
£1600 on an Ethernet cable is utterly laughable. FFS a £0.20 patch cable will have to be manufactured to the same spec or it won’t meet the category requirements. hmmm, we usually use blue cables for our network connections, we should try red, maybe that will sound better?
bigjimFull MemberHave you tried?
No, because I know the wiring inside my speakers, or to the terminals on the amp, is just normal (can’t remember the awg) wiring, so anything in between that isn’t thin or made from cheese can’t make any difference without the assistance of magicke. And I’m certainly not spending loads of money on fancy named cables to confirm that! It’s just electricity, flowing through metal.
RustySpannerFull Memberask1974 – Member
Whilst I’m firmly in the camp that cables have a placebo type effect in that quality is perceived rather than improved, we used cables to make minor adjustments to systems to tailor the sound to the clients ear. Minor as they were time and time again this process worked so from experience there was (and still is) some impact cables play. Cost of cable was never a serious factor though, just a well manufactured cable.Very similar to my experience – small but repeatable differences.
bigjim – Member
Have you tried?
You don’t need to spend loads of money – try twin and earth mains cable versus a cheapo 79 strand type.
I’ll buy you a pint if you can’t tell the difference.
RopeyReignRiderFree MemberAsk1974 – just a little point but soundstage and imaging are nearly always linked to phase distortion or rather shift/time smear (or lack of it) amongst other things. It’s not something hifi companies generally like to talk about or advertise figures for but can have a massive effect. Speaker manufacturers like to publish a lovely “flat” frequency response graph yet don’t want to discuss phase.
I’m going to gracefully bog off out of this discussion now 🙂
slowoldmanFull MemberI’d argue that a pair of modern Adam, Mackie or JBL monitors are very accurate, brutally honest and non flattering in terms of reproducing all the frequencies and amplitudes of sound in the recording compared to hifi speakers.
Indeed. Which is why a lot of people think they are harsh and uncomfortable. Hi fi speakers tend to have an artificial hump in the bass to give plenty of “kick” and a nice warmth. This cuddly warmth is also why a lot of people still prefer vinyl. Accuracy is irrelevant for rock and pop because you’ve no idea what was on the original recording anyway – accuracy becomes a myth.
Most of my listening is classical and as a concert goer and amateur musician I have a pretty good idea what that really sounds like. So my vote is for CD, big solid state amps and properly designed, well built (old fashioned) speakers.
chiefgrooveguruFull MemberAspects such as sound stage and imaging are not ‘measurable’…
A point source loudspeaker with perfectly omnidirectional output and linear phase response and perfect transient response will have perfect soundstaging and imaging. Any divergence from a true point source, any less than perfect polar response and any variation in phase response or delay/overhang in transient response will disrupt the soundstage/imaging. It’s all measurable! It’s also completely impossible to achieve those ideal goals.
RustySpannerFull MemberCGG, why would a speaker cable comparison have no value?
Interested in your response.
chiefgrooveguruFull MemberCGG, why would a speaker cable comparison have no value?
I think if it’s properly tested it should – but from what I’ve read about using cables to tweak a system tonally sounds to me like the way you’d subtly tweak a passive loudspeaker crossover to suit a given room, in which case rather than buying expensive cables isn’t it better to measure the electrical effects of the cable and put those components in the crossover and use a hefty cheap cable with minimal electrical effects?
RustySpannerFull MemberCGG, I use cable to slightly tweak a system tonally because it’s more convenient than modifying a crossover.
The cost of the cable is irrelevant, btw.I’m still not clear if you believe that different speaker cable will affect the sound of a passive system.
You say it ‘should’, which would suggest you do, but I assume this is not something you’ve tested yourself?Just interested in the views of someone who does this sort of thing for a living.
CountZeroFull MemberOne upside of getting into loudspeaker design was discovering that when it comes to speaker cable you’d be very well served by standard 13A mains cable!
Hmmm, this goes right back to the early eighties when I used to read hifi mags regularly, ‘cos I used to sell it.
HiFi News & Record Reviews was my ‘bible’ especially Ken Kessler’s page at the back.
Anyhoo, I remember reading all sorts of stuff about fancy OFC cables, directionality, and all that stuff, but it was pointed out that using 13A solid core mains cable made just as good a speaker and interconnect cable as stuff costing tens of pounds per metre.
I’m with CGG, I enjoy listening to 6Music through a plastic Pure One tranny, and my home system is a Yamaha DSP-AX2 amp into Sony Pascal 5.1 surround speakers, with most music from my Mac Mini fed vis TOSLink ripped at 320Kb.
The speaker wire is all basically bell-wire, more or less, and I’ve been getting a huge amount of enjoyment from it for getting on fifteen or more years now. (Minus the Mac, that’s just a couple of years old).
Truth is, I get more obsessive about my in-ear monitors, because I spend more time listening to music via an iPod or phone, and it’s much more intimate, I can hear greater variation in mastering and such like because the music comes straight to my eardrums.
And I can’t afford to upgrade my home audio system anyway.RustySpannerFull MemberCountZero – Member
Anyhoo, I remember reading all sorts of stuff about fancy OFC cables, directionality, and all that stuff, but it was pointed out that using 13A solid core mains cable made just as good a speaker and interconnect cable as stuff costing tens of pounds per metre.I assume you conducted your own comparisons before reaching the conclusion that cabling is merely ‘Voodoo’?
somafunkFull MemberHere’s a good website for those interested in taking this discusssion any further or if you wish to test your system or ears Audiocheck/sound tests/tone generators/blind audio tests
It’s been an entertaining thread so far, but the lack of pics and diagrams is below par for stw, so here’s a nice sounding PMC MB2i tuned and custom specced by someone with 25yrs experience as a BBC Radio sound engineer, they’re for sale btw,
he’s also got a cracking selection of personal DAT recordings from his bbc days . Ti’z a shame i have to settle for my common/garden variety KRK Rokit 5 monitors and KRK 10s sub when i’m at home, 24bit/192kHz recordings whenever possible of course….we’re all about the Linn Recordings here don’t ya know 😉 .Don’t spend £300 on cables, spend it on room acoustics instead – that will make a significant difference or if your wife/girlfriend will take offence to things hanging on the wall and big foam lumps in the corners then invest in decent quality headphones or in-ear monitors….but that’s an entire thread all of it’s own.
RustySpannerFull MemberThat’s a very interesting web site – addictive too. 🙂
I’m all ears 😀
Not very good ones, admittedly.mrmonkfingerFree MemberSo my vote is for CD, big solid state amps and properly designed, well built (old fashioned) speakers.
I’m with you.
bigjimFull MemberIndeed. Which is why a lot of people think they are harsh and uncomfortable.
I do find the top end tiring depending on the kind of music.
I think van damme blue is the one I’ve heard being used most by pros, or in studios etc, and its cheep cheep.
The topic ‘£1600 audio ethernet cable’ is closed to new replies.
